Civil 3D Forum
Issues when placing labels on feature lines
4 REPLIES 4
287 Views, 4 Replies
How do i edit the settings where the label grip is placed on the label attachment point, to be exact i want be grip to be placed at the start/end elevation points.
4 REPLIES 4
tcorey
Edit the label style, Layout tab, select your component from the components list, set Anchor Point to Label Location
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
in reply to: tcorey
When i do that the label goes to the middle of the line?
AllenJessup
You have to do one for each. This is for the Start.
Then you need one for the end.
Allen Jessup
CAD Manager - Designer
lynn_zhang
Hello @Anonymous ,
Just checking to see if your problem has been solved. Did the suggestions from our experts above work for you? If yes, please click on the "Accept as Solution" button in their reply so this helps other users in the community find the solution too. Thanks!
Lynn Zhang
Rail Community
