Highlighting feature prospector
This widget could not be displayed.
Please see attached.
In tool space, prospector, master view, when you click a text, it highlights that object in the model space. Can someone tell what is this feature and how to do setting in it? . Such as the highlighted object is red, can I change the highlight color to other colors? And this feature is only for the corridor?
cwr-pae
I believe the edit highlighting is only available for corridors and alignments. Colors  for both can be changed under their respective feature headings in settings. In corridors it is called "Region Highlight Graphics", in alignments it is called "Dynamic Alignment Highlight Options". The alignment highlighting shows when using the table view in alignment geometry editing.
lynn_zhang
Hello @Anonymous ,
Just checking to see if your problem has been solved. Did the response from @cwr-pae help answer your question? If yes, please click on the "Accept as Solution" button in his reply so this helps other users in the community find the solution too. Thanks!
Lynn Zhang
