Civil 3D Forum
Grading Plan in Civil 3D
3 REPLIES 3
540 Views, 3 Replies
I need to do grading plan in civil 3D. I have the elevation value at different points of a site. I just need to show the elevation of each point in 3D . How to do this for a complete plan (Ex: a parking lot)
3 REPLIES 3
MMcCall402
You can create a surface using the elevation values you have at the different points across the site. (make surface, edit surface, add points)   Once you have the surface you can then label any location within the surface with an elevation label.  These labels will dynamically update if the surface needs to be edited further.
Mark Mccall
CAD Mangler
Hammer Land Engineering
Linkedin
tcorey
Only need to label the elevations and don't need a surface? Use COGO Points.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
lynn_zhang
Hi @Anonymous ,
Just checking to see if your problem has been solved. Have you tried the suggestions from our experts above and did they work? If yes, please click on the "Accept as Solution" button in their reply so this helps other users in the community find the solution too. Thanks!
Lynn Zhang
Rail Community
