I need to do grading plan in civil 3D. I have the elevation value at different points of a site. I just need to show the elevation of each point in 3D . How to do this for a complete plan (Ex: a parking lot)
Solved by MMcCall402. Go to Solution.
You can create a surface using the elevation values you have at the different points across the site. (make surface, edit surface, add points) Once you have the surface you can then label any location within the surface with an elevation label. These labels will dynamically update if the surface needs to be edited further.
Only need to label the elevations and don't need a surface? Use COGO Points.
Hi @Anonymous ,
Just checking to see if your problem has been solved. Have you tried the suggestions from our experts above and did they work? If yes, please click on the "Accept as Solution" button in their reply so this helps other users in the community find the solution too. Thanks!
