How do i edit the settings where the label grip is placed on the label attachment point, to be exact i want be grip to be placed at the start/end elevation points.
Solved by AllenJessup. Go to Solution.
Solved by tcorey. Go to Solution.
Edit the label style, Layout tab, select your component from the components list, set Anchor Point to Label Location
You have to do one for each. This is for the Start.
Then you need one for the end.
Allen Jessup
CAD Manager - Designer
Hello @Anonymous ,
Just checking to see if your problem has been solved. Did the suggestions from our experts above work for you? If yes, please click on the "Accept as Solution" button in their reply so this helps other users in the community find the solution too. Thanks!
