Civil 3D Forum
Intermediate software for Revit and civil 3d
3 REPLIES 3
sanetdikkumbura1950
263 Views, 3 Replies
What is the intermediate software that can easily sync objects, surfaces, models etc. between civil3d and revit?
How to sync a civil 3d drawing with units and zone with Revit?
3 REPLIES 3
You can download the Autodesk Desktop Connector for best practices in offline and online sharing projects between Revit and C3D.
If you’re creating a surface on C3D, for example, it can easily be shared on DOCs and openned in Revit just choosing the project in Link Topography
Here’s a video from Jeff Bartels that can help you in this process:
Paulo Santos | BIM Expert | LinkedIn | Contatos |
You could always use the Shared Reference Point tool in the Toolbox.
Autodesk Civil 3D Help | To Work with the Shared Reference Point Tool | Autodesk
Rick Jackson
Survey CAD Technician VI
If you don’t have a360 then you cannot import directly from c3d
instead use a combination of 3d faces (as regions) via dwg export in a generic mass family or ifc exports for pipe work.
corridors and surfaces also as 3d solids.
forget toposurfaces from c3d without a360. Revit will mess up the triangulation if you have walls, kerbs or banks.
search in here or revit forum as I’ve explained the method a few times before.
mike
Mike Evans
Civil3D 2022 English
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~4.0GHz With 32768MB RAM, AMD FirePro V4900, Dedicated Memory: 984 MB, Shared Memory: 814 MB
Rail Community
