Inserting PI point error possible reasons?
just pop up this error in the command line. Can we discuss the possible reasons here? Thanks
One possible reason came to my mind it the point I am inserting is has a little bit interaction with other feature lines.
rgilbert_JHA
Are you trying to insert a PI along the existing feature line?  If so, I have that problem at times and simply add a PI off to the side then grip edit it to the horizontal location I originally intended.  Annoying workaround, but that may solve your problem.  I have never identified a specific cause, sorry.
Robert Gilbert
