Alignments and Named Plot Style
mporretto
Message 1 of 8
mporretto
Hi, All.
I'm working with STB and I had set Civil 3D 2018 to create all alignments in "00-ST-C3D-OBJETO-ALIGNMENT" on Object Layers tab under Drawing Settings.
I also create a layer named "00-ST-C3D-OBJETO-ALIGNMENT" for the centerlines of the road that use "255-100-0.50" plotstyle.
This plot style plot the lines, curves and spirals with 255 color (working over images) at 0.50 mm lineweight.
When I plot my centerline I get a black line with 0.10mm lineweight and not a white line with 0.50 lineweight as my STB.
As you can see, my stations, label stations, line extensions, everything use the colors of the STB, but not the centerlines.
Can you help me?
Thanks in advance and I'm sorry about my english.
Marcello Porretto
Rio de Janeiro / Brazil
Replies (7)
Message 2 of 8
civilman1957
Check your alignment styles under "display". You can override plot weights, line types and colors in the style. Unless you want to override, set everything in the style to "by layer."
Cad Manager/Senior Engineering Technician
Autodesk Certified Professional
Intel(R) Core (TM) i7-7700 CPU
3.60 GHz/24 GB BEAST
Civil 3D 2013/2014/2017/2018/2020
Message 3 of 8
MMcCall402
Is it possible you have a layer viewport plot style override?
Mark Mccall
CAD Mangler
VHB - Engineering, Inc.
Message 4 of 8
mporretto
Hi CivilMan1957,
Everything is BYLAYER.
Thanks!!!
Message 5 of 8
mporretto
Hi MMcCall402,
I'm plotting from Model. No Viewports.
Thanks!!!
Message 6 of 8
civilman1957
MMcCall402 has a good point....viewport overrides?
Message 7 of 8
civilman1957
Does it look correct on the screen?
Message 8 of 8
mporretto
Wow, I got it!!!!!
Every components from the aligment (lines, curves and spirals) are set to a layer with yellow color but plot with a plot style at white color with 0.60 mm linewight. The extension lines are set to a layer with yellow color too, but plot with a plot style at red color with 0.25 mm linewight. For that, the alignment object should be with Plot Style = BYBLOCK...
Now the plot looks great...
Thank you everybody!!!!!!
