TIN lines should be always on corridor links, especially in the daylights. When "daylight" FL has angled corners, then TIN lines are wrong and the slope is not correct.
I would like an option to force TIN lines on links.
Solved by joantopo. Go to Solution.
Ok, I have solved it enabling the checkbox "add breakline" in the corridor.
Hi @joantopo
I just wanted to let you know that I’ve just accepted your reply to your post as a solution with the understanding that this solution solved your issue.
If your answer did not work as a solution, please reply to this message so, that I can unmark the solution, and we can continue the conversation.
I wanted to point out that if the opportunity arises again, you can also click on the ‘Accept as Solution’ button if/when relevant so, that others can more easily benefit from the information.
Please feel free to let me know if you have any questions or concerns I am here to help!
