Civil 3D Forum
Improving corridor surface (TIN lines always on links)
3 REPLIES 3
joantopo
682 Views, 3 Replies
TIN lines should be always on corridor links, especially in the daylights. When "daylight" FL has angled corners, then TIN lines are wrong and the slope is not correct.
I would like an option to force TIN lines on links.
Autocad C3D 2019 SP3, 2020 & 2021
Intel I9 9900K with frontal watercooler alphacool eisbaer 360 (original fans mounted in pull)- 3 fans Corsair 120 ML PRO in push.
MOBO Gygabyte Z390 Aorus Master- Corsair RGB Vengeance 64GB RAM (4x16) CL16
Nvidia Quadro RTX 4000
Samsung 970 EVO PLUS 1TB (unit C). Samsung 970 PRO 512GB (for data)
Power Supply: Corsair TX850M PLUS
Descubre mi programa VisorNET para Civil 3D:
https://apps.autodesk.com/CIV3D/es/Detail/Index?id=appstore.exchange.autodesk.com%3avisornet_windows32and64%3aes
Labels (1)
3 REPLIES 3
CNinBC
in reply to: joantopo
you might be able to resolve this by adding link(s) as breakline(s)
joantopo
Ok, I have solved it enabling the checkbox "add breakline" in the corridor.
BushW
Hi @joantopo
I just wanted to let you know that I’ve just accepted your reply to your post as a solution with the understanding that this solution solved your issue.
If your answer did not work as a solution, please reply to this message so, that I can unmark the solution, and we can continue the conversation.
I wanted to point out that if the opportunity arises again, you can also click on the ‘Accept as Solution’ button if/when relevant so, that others can more easily benefit from the information.
Please feel free to let me know if you have any questions or concerns I am here to help!
Wendell Bush
Civil Infrastructure Technical Support Specialist
Rail Community
