Hi Everyone,
I have tried looking for a solution but normal channels (youtube, google, forum search) did not produce results I need. I have a Road alignment with multiple pipe networks (pressure, and non pressure). I created a Continuous Profile view along the entire stretch of the alignment and also Multiple segmented views of the same alignment for plotting purposes.
Problem I would like to resolve is that how do I get all profile views to reflect the same content? Meaning if I add a new pipe to the continuous profile view, or add labels, have it also reflect on the multiple segmented view that corresponds to that segment. Maybe its not possible but I would love them to behave as one. Thanks in advance!
Solved by MMcCall402. Go to Solution.
Not gonna happen.
Plan Production would be the easiest way. Otherewise, new pipes would have to be added after the fact
Joe Bouza
Idea:
Three viewports in papaperspace. One large one centered over the section of the overall profile view you want to show on that sheet. On each side of that a narrow viewport of each end of the overall profile, just wide enough to show vertical axis labeling for each end of the profile view. For other sections of the profile copy those three viewports and recenter the middle viewport to the next section. Note: some labeling may need to be repeated as a needed label may fall outside the current viewport.
