- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I frequently encounter a problem where attached raster images become unreadable. This happens when I open a file that has an image attached and I redirect the path to a different image. The sources and format of the images are identical so I know it is not a compatibility issue. I can detach and reattach no problem.
This also just happened in a file that had an attached image that didn't change in any way. The path didn't change, the image didn't change, yet when I opened the file, the status was Not Found in the XREF manager, even though the path in the setting was right. I went ahead and re-applied the path, then the status changed from Not Found to unreadable. See attached screen capture.
I can't find any forum posts on this issue so it doesn't seem to be a common problem. Anyone know what is going on?
I am using Civil 3D 2023.
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
