Civil 3D Forum
Hydraflow & Pipe Networks - Split Flow
1 REPLY 1
359 Views, 1 Reply
Hello
I am trying to setup a model which involves sending a portion of flow to a BMP structure (between lines 2 & 3) and the rest will bypass the BMP through a separate structure (between lines 25 & 26). The issue I am having is at the structure where the flow is split. As the system is setup by down stream line number I am unable to set up 2 downstream pipes in Hydraflow Storm Sewers.
As you can see i would like the flow from the combination of 4+24 to first flow through line 3 until the invert of line 26 is reached and then continue flowing through both pipes.
Does anyone have any suggestions to edit the model or suggestions for using a different program/model?
Thank you in advance for your time!!
Labels (2)
1 REPLY 1
fcernst
Only one line can leave a junction..not two.
You could use a Generic Inlet with a certain limited capacity such that it bypassses the BMP flow (Total Flow-Generic Inlet Intercepted flow) amount to another junction...
Fred Ernst, PE
C3D 2025
Ernst Engineering
www.ernstengineering.com
Rail Community
