Civil 3D Forum
How to turn off the layer of analyazed elevation realated to the surface in second layout!?
6 REPLIES 6
giscivil92
312 Views, 6 Replies
Hello everyone
I have two layouts, one of them shows the analyzed elevation surface and another one shows the contour lines without analyzed elevation! how can I turn off the layer of analyzed elevation surface only in the second layout (contour line map)!?
Thank you
Labels (2)
6 REPLIES 6
rl_jackson
in reply to: giscivil92
If you place the Elevation part of the display style for the surface on it's on layer, you'll have control over that in the viewport.
Rick Jackson
Survey CAD Technician VI
giscivil92
in reply to: rl_jackson
Yes, I did that already but the issue is when I turn off the layer the analyzed elevation be turned off in two layers!
Although I want to turn it off only in one layer!
rl_jackson
Do a Viewport Freeze of the layer in question.
Rick Jackson
giscivil92
Not efficient because the whole surface be freezed!
jarek_zal
The easiest way is to create a second layer and move the surface to it, by selecting and changing it.
And then as suggested above freeze in viewport.
Jarek
rl_jackson
You're doing a layer freeze, do a viewport freeze. I had 0 issues with the elevation banding disappearing in the viewport that is in the image I provided previously.
Surface with Contours and Elevations Bands
Without Elevation banding.
Rick Jackson
Rail Community
