XREF'ing cogo points of a tree survey into a sheet .dwg. The cogo point labels in the survey file look how I want them to look, however when XREF'd in to my sheet, a large X and circle appear on the tree label. I have toyed around with all the different label settings but nothing has worked. See attached screenshots. The first is the survey file, how I would like the tree labels to look when XREF'd. The second is how they are appearing when XREF'd. I am running CIVIL3D 2022.
Solved by TerryDotson. Go to Solution.
Good. Posting how you resolved it useful to others
Christopher Stevens
... how you resolved it useful to others
My guess is PDMODE = 0 followed by a Regen.
