I am working on create curve for a profile, it will be very helpful if every PVI shows tangent grade changes in angle.
Please refer to enclosed pic for details:
Rad is profile, i want to get angle which is yellow, I always add 2 line (green) and make a dimension of angle to complement it, too complicated.
I have tried Profile label, but I cant find the right one, Grade Break seems close to my requirement , but
Very appreciate for any advice,
天涯海角的山姆
您认为此帖子是否有用?欢迎为此帖点赞。
您的问题是否已得到解答?请点击“接受解答”按钮。
Solved by MMcCall402. Go to Solution.
Solved by schroederC3D. Go to Solution.
Two things:
If this solves your issue or answers your question then please hit the KUDO button or mark as an ACCEPTED SOLUTION!
Adjusting the weeding the the profile label properties should get the 'missing' PVI labels to appear.
The Grade Change in the label style won't give you an angular value. You will need to make an Expression with the formula to calculate the angle. In Toolspace, -->Profile, -->Label Styles, -->Grade Breaks, you should see Expressions at the bottom of the list of available grade break label styles. Select it an choose New. Name the new expression and in the Expression area you can build the formula. (ATAN({Grade Change})) Set the value result to Angle. When you return to your grade break label style the name of the new expression should appear as an available property for the label.
天涯海角的山姆
您认为此帖子是否有用?欢迎为此帖点赞。
Red is Expression, Blue is Weeding adjustment, I put 2 here , then every PVI shows "Grade Break" label.
I understand Weeding make sense as sometimes people maybe just want special parts outstood by labels.
(you can see Angle has been correctly showed in drawings. Many thanks to both above!)
天涯海角的山姆
您认为此帖子是否有用?欢迎为此帖点赞。
天涯海角的山姆
您认为此帖子是否有用?欢迎为此帖点赞。
天涯海角的山姆
您认为此帖子是否有用?欢迎为此帖点赞。
