Civil 3D Forum
How to show grade change in angle on Profile?
6 REPLIES 6
TiStars
2720 Views, 6 Replies
I am working on create curve for a profile, it will be very helpful if every PVI shows tangent grade changes in angle.
Please refer to enclosed pic for details:
Rad is profile, i want to get angle which is yellow, I always add 2 line (green) and make a dimension of angle to complement it, too complicated.
I have tried Profile label, but I cant find the right one, Grade Break  seems close to my requirement , but
  1. Labels don't come on every PVI, just some of them , I don't know why.
  2. It can only shows grade change instead of angle, I got a formula of "ATAN({Grade in}---{Grade out})", but i don't know where to put it in.
Very appreciate for any advice,
天涯海角的山姆
您认为此帖子是否有用?欢迎为此帖点赞。
您的问题是否已得到解答?请点击“接受解答”按钮。
6 REPLIES 6
schroederC3D
in reply to: TiStars
Two things:
  1. Make sure weeding is adjusted appropriately to show grade break labels for your PVIs,
  2. Use Grade Change in a label component to report the change in grade between incoming/outgoing tangents:
If this solves your issue or answers your question then please hit the KUDO button or mark as an ACCEPTED SOLUTION!
Reply Syntax?
Command (Uppercase): TRIM, Variable (Italicized): MSLTSCALE, Civil 3D Object (Within brackets): [SITE]
Please support my Idea to revert the forum format to the old one: https://forums.autodesk.com/t5/community-ideas/revert-to-old-forum-layout/idi-p/7917987
MMcCall402
Adjusting the weeding the the profile label properties should get the 'missing' PVI labels to appear.
The Grade Change in the label style won't give you an angular value.  You will need to make an Expression with the formula to calculate the angle.  In Toolspace, -->Profile, -->Label Styles, -->Grade Breaks, you should see Expressions at the bottom of the list of available grade break label styles. Select it an choose New. Name the new expression and in the Expression area you can build the formula.  (ATAN({Grade Change}))  Set the value result to Angle. When you return to your grade break label style the name of the new expression should appear as an available property for the label.
Mark Mccall
CAD Mangler
Hammer Land Engineering
Linkedin
TiStars
the right formula will be:
ABS(RAD2DEG(ATAN({Grade In}-{Grade Out})))
天涯海角的山姆
您认为此帖子是否有用?欢迎为此帖点赞。
TiStars
Red is Expression, Blue is Weeding adjustment, I put 2 here , then every PVI shows "Grade Break" label.
I understand Weeding make sense as sometimes people maybe just want special parts outstood by labels.
(you can see Angle has been correctly showed in drawings.  Many thanks to both above!)
天涯海角的山姆
您认为此帖子是否有用?欢迎为此帖点赞。
TiStars
in reply to: schroederC3D
Thanks, I took me some time to understand " weeding is adjusted appropriately" and find where to adjust.
I am using C3D 2016, I think you are saying "Grade Break"?
天涯海角的山姆
您认为此帖子是否有用?欢迎为此帖点赞。
TiStars
in reply to: MMcCall402
Thank you, I like " In Toolspace, -->Profile, -->Label Styles, -->Grade Breaks, you should see Expressions " , it shows me easily where Expression is. I recalled that I saw it before.
I attached a pic to show where is expression and weeding
天涯海角的山姆
您认为此帖子是否有用?欢迎为此帖点赞。
Rail Community
