How to disable xref compare?
不适用
28,479 次查看
23 条回复
1 条消息(共 24 条)
不适用
This new xref compare popup is driving me nuts.  How do I disable it?
已接受的解答 (1)
28,480 次查看
23 条回复
回复 (23)
2 条消息(共 24 条)
pendean
Community Legend
Community Legend
Stop using the command?
3 条消息(共 24 条)
Joe-Bouza
...Doc it hurts when I go like this...😂😂😂
Joe Bouza
4 条消息(共 24 条)
不适用
Funny...!  Have you even used ver 2021?  Every time you change an xref it kicks you into the xref compare editor.  There is a box you can uncheck that will prevent it from doing this.
5 条消息(共 24 条)
pendean
Community Legend
Community Legend
Been on it full time for a month now, thanks for asking.
>>>...There is a box you can uncheck that will prevent it from doing this...<<<
So you found the fix? Thanks for sharing, please tag your last reply as the solution here.
0 个赞
6 条消息(共 24 条)
AllenJessup
已接受的解答
Try setting XCOMPAREENABLE to 0.
Allen Jessup
CAD Manager - Designer
7 条消息(共 24 条)
不适用
That did it - THANK YOU!
0 个赞
8 条消息(共 24 条)
不适用
Nurse, hand me my gloves... lol!
0 个赞
9 条消息(共 24 条)
jboehm84P52
Thank you for the actual response, as opposed to the idiots in the peanut gallery chiming in. After 10 years of clicking on the reload xref popup, re-training yourself NOT to click on a popup in the same area (even after unchecking xref compare, a separate comparison popup will still sometimes appear) is a headache.
10 条消息(共 24 条)
不适用
I have the same issue. Setting XCOMPAREENABLE to 0 results in an error message stating "XCOMPAREENABLE is not allowed during XREF Compare"...! How does one STOP and XREF compare? I've tried right clicking and double clicking the xref to no avail.
Thanks for any assistance.
0 个赞
11 条消息(共 24 条)
不适用
Found it! there is a floating toolbar that appears when using xref compare. Click the checkmark to end the compare.
12 条消息(共 24 条)
AllenJessup
A couple of thing I might suggest. One is to use the Express Tools System Variables Editor to try and change the variable as I show in post 6.
Another would be to add that to the monitored variables using SYSVARMONITOR or adding it to the acaddoc.lsp file.
Allen Jessup
13 条消息(共 24 条)
jreidCDS28
I started working on AutoCAD 2022 and this command works great to turn off the Compare.
I like the compare for some things but when working and you know what changed it slows down the workflow.
Thanks for Posting back on 06-03-2020!!
JRR.
14 条消息(共 24 条)
J.Cline
Thanks!  R-clicking and trying NOT to hit the compare button since it defaulted to where the reload all function was, was really getting old.  If AutoDESK would simply have put that feature in a NEW SPOT, say at the top of the mini-pop up list, I wouldn't mind that feature existing, because I could see how it could help when someone else changed a drawing.  But putting it where it was, was too much of an annoyance.  Way too many years of muscle memory to overcome for a feature I would barely use.
15 条消息(共 24 条)
wahyulpriawan10
Community Visitor
Community Visitor
Sir, you just save my life. Thank you
0 个赞
16 条消息(共 24 条)
oskar.erdoedy
Well, it is a handy functionality, but it should be mentioned that a viewport (in a layout) is automatically set to 2D Wireframe if the comparison is active and a change in an Xref is detected (at least on my 2022 installation). At first, I thought this is a bug (I didn't even know xcompare), my viewport always switched to 2D after changing an Xref and reloading it. Maybe there is a Sysvar for this, too ?
Or, since I generally do not work with revision clouds et al in Acad and therefore don't know them in-depht, maybe they need 2D WF mode for being displayed ?
EDIT: Sorry, I forgot to make this a reply to @AllenJessup
0 个赞
17 条消息(共 24 条)
AllenJessup
@oskar.erdoedy I believe you're right. But I don't have a definitive answer.
Allen Jessup
0 个赞
18 条消息(共 24 条)
noeortiz8009
Observer
Observer
Finally! a straight answer. Thanks Allen
19 条消息(共 24 条)
AllenJessup
@noeortiz8009
You're welcome. This seems to be my most "Liked" post.
Allen Jessup
20 条消息(共 24 条)
_Zaphod_
It's liked because you provided an actual solution - instead of being a snarky, condescending, sarcastic waste of space. So yeah ... THANKS!
