How to disable xref compare?
Message 1 of 24
This new xref compare popup is driving me nuts.  How do I disable it?
Replies (23)
Message 2 of 24
pendean
Community Legend
Community Legend
Stop using the command?
Message 3 of 24
Joe-Bouza
...Doc it hurts when I go like this...😂😂😂
Joe Bouza
Message 4 of 24
Funny...!  Have you even used ver 2021?  Every time you change an xref it kicks you into the xref compare editor.  There is a box you can uncheck that will prevent it from doing this.
Message 5 of 24
pendean
Community Legend
Community Legend
Been on it full time for a month now, thanks for asking.
>>>...There is a box you can uncheck that will prevent it from doing this...<<<
So you found the fix? Thanks for sharing, please tag your last reply as the solution here.
Message 6 of 24
AllenJessup
Try setting XCOMPAREENABLE to 0.
Allen Jessup
CAD Manager - Designer
Message 7 of 24
That did it - THANK YOU!
Message 8 of 24
Nurse, hand me my gloves... lol!
Message 9 of 24
jboehm84P52
Thank you for the actual response, as opposed to the idiots in the peanut gallery chiming in. After 10 years of clicking on the reload xref popup, re-training yourself NOT to click on a popup in the same area (even after unchecking xref compare, a separate comparison popup will still sometimes appear) is a headache.
Message 10 of 24
I have the same issue. Setting XCOMPAREENABLE to 0 results in an error message stating "XCOMPAREENABLE is not allowed during XREF Compare"...! How does one STOP and XREF compare? I've tried right clicking and double clicking the xref to no avail.
Thanks for any assistance.
Message 11 of 24
Found it! there is a floating toolbar that appears when using xref compare. Click the checkmark to end the compare.
Message 12 of 24
AllenJessup
A couple of thing I might suggest. One is to use the Express Tools System Variables Editor to try and change the variable as I show in post 6.
Another would be to add that to the monitored variables using SYSVARMONITOR or adding it to the acaddoc.lsp file.
Allen Jessup
Message 13 of 24
jreidCDS28
I started working on AutoCAD 2022 and this command works great to turn off the Compare.
I like the compare for some things but when working and you know what changed it slows down the workflow.
Thanks for Posting back on 06-03-2020!!
JRR.
Message 14 of 24
J.Cline
Thanks!  R-clicking and trying NOT to hit the compare button since it defaulted to where the reload all function was, was really getting old.  If AutoDESK would simply have put that feature in a NEW SPOT, say at the top of the mini-pop up list, I wouldn't mind that feature existing, because I could see how it could help when someone else changed a drawing.  But putting it where it was, was too much of an annoyance.  Way too many years of muscle memory to overcome for a feature I would barely use.
Message 15 of 24
wahyulpriawan10
Community Visitor
Community Visitor
Sir, you just save my life. Thank you
Message 16 of 24
oskar.erdoedy
Well, it is a handy functionality, but it should be mentioned that a viewport (in a layout) is automatically set to 2D Wireframe if the comparison is active and a change in an Xref is detected (at least on my 2022 installation). At first, I thought this is a bug (I didn't even know xcompare), my viewport always switched to 2D after changing an Xref and reloading it. Maybe there is a Sysvar for this, too ?
Or, since I generally do not work with revision clouds et al in Acad and therefore don't know them in-depht, maybe they need 2D WF mode for being displayed ?
EDIT: Sorry, I forgot to make this a reply to @AllenJessup
Message 17 of 24
AllenJessup
@oskar.erdoedy I believe you're right. But I don't have a definitive answer.
Allen Jessup
Message 18 of 24
noeortiz8009
Observer
Observer
Finally! a straight answer. Thanks Allen
Message 19 of 24
AllenJessup
@noeortiz8009
You're welcome. This seems to be my most "Liked" post.
Allen Jessup
Message 20 of 24
_Zaphod_
It's liked because you provided an actual solution - instead of being a snarky, condescending, sarcastic waste of space. So yeah ... THANKS!
