How to cut/ merge to different Subassemblies ?
kamu7TNKT
Observer Observer
kamu7TNKT
Observer
Observer
Hi Colleagues,
How to assemble 2 different corridors. In this case, it is a stone setting and an excavation that must be assembled. A colleague mentioned that it should be done with "Intersection" Is there anyone who can help ?
cwr-pae
You can merge the interface of two corridors using targeted subassemblies. You will need to line, feature line or alignment & profile at the interface between the two to target. You may want to target both assemblies. After you have the target go to the parameters tab and find the target button for the assembly region you want target. Set the links targets for the width and elevation as appropriate, then update the corridor.
With out seeing your assemblies and probably you plan and profile, it's difficult to give precise instructions. If you can attach the drawing I, or someone else, will be able to give much information.
lim.wendy
Hi Karsten,
Good day to you. Thank you for submitting your question in our discussion forums.
I see you are visiting as a new member of the Civil 3D forum. Welcome to the Autodesk Community!
Have you had a chance to look over the suggestions provided by our experts?
Please let us know if you require further assistance.
If the suggestions helped you, please hit the "Accept Solution" button, as it helps make the solution easier to find for others who might have the same issue. Knowing which topics are solved or not can also help our many users find the questions that still need to be answered. It’s also a great way to say thank you and give recognition to whoever helped you.
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
chriscowgill7373
a lot of times, what I'll do in a situation like this, is place a feature line at the last good known frequency of each corridor, and one at the joint line between them, and then create a little micro surface that can be pasted over the corridor surfaces to "clean that up".  It may not be the best method for modeling, but it definitely is easier in some cases than trying to get a corridor to miter correctly.
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2024 on Windows 10
