Default Daylight Subassembly?
ieatspam5999
ieatspam5999
Say I want a subassembly in a fill condition to slope to an existing surface at a 10% slope, but if the slope width is greater than, let's say, 5 feet, the slope changes to a 50% slope after 5 feet to meet the existing surface.
Is there a default subassembly that does this? Or would it have to be a custom?
Thanks in advance.
cwr-pae
I'm not sure about daylight subs, I rarely use them. But a simple "ConditionalCutOrFill assembly with generic "LinkSlopeToSurface" and "LinkWidthAndSlope" will do it with a minimum of fuss.
ieatspam5999
hey thanks. ive been playing around with those subassemblies and i just cant get the conditional cut or fill to work. im thinking it using the min and max distance to set the conditions?
condition 1: distance = 0 to 4.99, insert assembly to grade to surface at 10%
condition 2: distance = 5.0 to 9999, insert assemblies to grade at 10% for 5.0 feet then grade to surface at 33%.
is this correct?
cwr-pae
Your approch sounds right, but its never that simple.
Try the attached set up. Just copy and paste from my fill to yours, the use the "copy to" command in the right click menu to add them to your assembly. Or use it as a guide to create yours. I used a "LinkSlopeAndVerticalDeflection" in stead of the "LinkWidthAndSlope" I recommended yesterday, it might serve your purpose better.
Note: The conditional fill assemblies have to target the surface in the corridor.
ieatspam5999
okay i see, the min-max distance is measuring the y distance not the x distance. which i can back calculate with the x distance and slope.
lim.wendy
Hi @ieatspam5999,
Thanks for reaching out to the forum. I see you are visiting as a new member of the Civil 3D forum. Welcome to the Autodesk Community!
It seems like Charle's reply was indeed on the right track and provided a helpful solution to your query, so for now, I will mark this thread as "Solved." This won't prevent other folks from commenting on this question though, in the event other ideas come up!
Please let us know if you require further assistance.
If the suggestions helped you, please hit the "Accept Solution" button, as it helps make the solution easier to find for others who might have the same issue. Knowing which topics are solved or not can also help our many users find the questions that still need to be answered. It’s also a great way to say thank you and give recognition to whoever helped you.
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
