Expected Accuracy of Geolocation Imagery
idigg-be
Message 1 of 33
idigg-be
we have a surveyor giving us points that he claims are on state plane.  when bringing them in, they are anywhere from 10-15' away from the geolocation imagery.
I have brought in gis data from our state's official source, including LIDAR contours, imagry, and breaklines.  that all agrees with the geolocation imagery built into autocad.
what degree of accuracy can i expect.  The surveyor is insisting that it is on state plane.  from what i understand from numerous other contacts in the field..  if the points were on state plane, they would be spot on.  maybe a foot or 2.
at what degree of inaccuracy can i confidently state that no, these points are not on state plane?
is there anything on my end that i might be doing to not have the correct location?  drawing is set to the correct zone(nad83 pa south zone, foot), projection lm, datum nad83.  i have not used the "mark position" or "edit location" or any other options in the geolocation tab.
Replies (32)
Message 2 of 33
cneelyUFTR2
Personally I never trust aerials to be that precise. It might be a difference between Surface-Grid, but it's usually a greater difference than 10'-15'. What is the geographic area you are in? Post the drawing and GIS data if you can.
Message 3 of 33
idigg-be
im not looking for anything that "precise", but when  i get drawings from other reputable companies, their files all overlay almost exactly on the other data we insert.  it seems to be only info from this guy that we have issues with.  btw, i was editing my original post with more info when you responded.  please check it out.
Message 4 of 33
cneelyUFTR2
Both can be in the same State Plane but if one is surface (ground) and the other is grid (plane) they wont line up. Need more info to be able to tell however.
Message 5 of 33
_Hathaway
It 'should' be on state plan if they claim so.  10-15' wouldn't normally be a grid to ground conversation and if it was there wouldn't be a valid reason to bring it to ground.  The geolocation tool is somewhat accurate but by no means should be the ultimate decider of state plane or not.  I would provide them with the information you have uncovered and let the producer of the data respond.
Message 6 of 33
Pointdump
Hi Wes,
Might also be a difference of datums: NAD83, NAD83(HARN), NAD83(NSRS2011), etc...
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
Message 7 of 33
idigg-be
@Pointdump wrote:
Hi Wes,
Dave
as far as i know people only use nad83 in our area.  ive never heard of harn, 2011, etc.  So i would assume WE are on the correct datum... but idk about him.   is that something i should ask him?
not sure if it is relevant, but it is not just a horizontal shift, but it is also on a different rotation.
Message 8 of 33
idigg-be
im not sure what the grid/ground reference is, but it is not just a shift; it is also a rotation issue.  i will try to get the files available when i get a break at work.   should i just insert the points over some lidar info and share that dwg?
Message 9 of 33
idigg-be
so grid vs ground is above my knowledge base.  im not sure how or why one would bring it to ground.
also, as mentioned elsewhere, there was also a rotation issue.
 i have literally showed the surveyor what the issue is and he has insisted that it is state plane.  he is a contractor that we use to do our surveying.  not a company, not an employee.  just a guy that we hire to do the work.
the burden of proof is on me to convince everyone around me that something is not correct.
dwg is attatched.  using the utility poles as reference you can see that the points are not just shifted.  and my mistake... it is actually a ~50' horizontal error.
Message 10 of 33
idigg-be
@cneelyUFTR2 @Pointdump i posted the dwg above.  just a portion of their points, and the white lines are our states gis breakline data inserted with mapimport..
the horizontal error is actually 50'.  and as you can see, not on the same rotation.
Message 11 of 33
cneelyUFTR2
Is that the actual drawing you received from the surveyor or one you created from that data?
Message 12 of 33
tcorey
That size bust in our geo is almost always caused by having one data set in International Feet and one set in US Survey Feet. It's a minuscule percentage difference but it adds up because of being millions of feet from the origin.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 13 of 33
idigg-be
the surveyor sends us a txt file with pnezd points in it and nothing more.  i took that, inserted it into our dwg, turned on geolocation imagry and inserted breaklines from https://maps.psiee.psu.edu/ImageryNavigator/
drew 4 lines connecting his utility pole shots to the approximate location of the utility poles on the aerial...saved and uploaded.
Message 14 of 33
cneelyUFTR2
The line in the screen shot below is in the middle of the street.
Ask the surveyor for a Combined Scale Factor.
Message 15 of 33
idigg-be
when i open the dwg it shows as directly over the utility pole.  not sure what is causing the discrepency..
Message 16 of 33
cneelyUFTR2
Well that was unexpected. Try to get the Combined Scale Factor. That could likely fix things.
Message 17 of 33
idigg-be
i have no idea what that means or how to ask him for it.
is it a per job thing or just a file that he is using, or a calculation he is doing?
Message 18 of 33
cneelyUFTR2
Phrase it as "Can you provide the Combined Scale Factor for this project?". He should know what it is.
Message 19 of 33
Jerry_Barnes
When I open the drawing, I get what idigg-be got... it looks pretty dead-on to me.
Message 20 of 33
_Hathaway
A contractor doing surveying...what could go wrong?  Not to diminish his talents but contractors should contract, not survey.  It's obvious there is a problem, a problem a competent surveyor should be able to figure out quickly.  I know this doesn't help your cause but you should let your manager know the situation.  If they say proceed, document it and proceed.
