How do you handle dynamic north arrows for your organization?
BrianHailey
Mentor Mentor
Message 1 of 15
BrianHailey
This question is primarily directed at CAD/BIM/VDC/WhateverYouWantToCallYourself managers but all are welcome to comment.
How do you manage the dynamic north arrows for your company? These are the north arrows that are dynamically linked to your viewports. If the viewport rotation changes, the north arrow changes and vice-versa.
My understanding is, to have a custom north arrow show up for all users without them having to add their own custom north arrow, the north arrow has to be added to the following drawing: "C:\Program Files\Autodesk\AutoCAD XXXX\Map\Sample\Symbols\Map - North Arrows.dwg". The problem with this is, it requires admin rights to modify this file and, it's location is hard coded into Map 3D. I can't put it up on a network or in our CAD support directories, it has to stay at that location. Additionally, it requires admin permissions to modify it which means that our Robocopy routines won't be able to update it when needed.
Has anyone actually been able to implement this for their organization? And if so, how?
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Replies (14)
Message 2 of 15
ToddRogers-WPM
WAY too many issues with them. I have seen layout corruption, views getting messed up, zooming automatically, etc. This is with the UCSFOLLOW set to 0 as well. So, we do NOT use them whatsoever.
Todd Rogers
Civil Administration at Walter P Moore
Message 3 of 15
rl_jackson
The views and north arrow is linked in our template sheets, that are used for PP or just Plan sheets, and the dwt says created with an earlier version (if that helps), but I'm with @ToddRogers-WPM that I've personally had nothing but issues with this corrupting view ports and making things just disappear that I can't say that I'd recommend it.
Rick Jackson
Survey CAD Technician VI
Message 4 of 15
BrianHailey
@ToddRogers-WPM and @rl_jackson, I trust you both and if you say there are too many issues to justify using them, then that's good enough for me. Thanks for the info!
GEI Consultants
My Civil 3D Blog
Message 5 of 15
ToddRogers-WPM
Going to NOLA @BrianHailey ?
Todd Rogers
Message 6 of 15
BrianHailey
Planning on it. Haven't submitted anything yet.
GEI Consultants
My Civil 3D Blog
Message 7 of 15
ChrisRS
I agree with @ToddRogers-WPM and @rl_jackson .
I guess that I am just old-school.
I believe that Standards and Company Data belong on servers, not local machines.
Civil 3D is like a male dog. It seems to leave a mark wherever it has been.
Civil 3d is also a mutt. Part AutoCAD, part Map 3D, part Architecture and a poorly fitted pressure pipe philosophy from Plant 3D.
This can be efficient but targeting blame and responsibility becomes very difficult as seen here.
I have been at this for over 40 years. One of the first things I learned is that every plan sheet has a north arrow and scale. Civil 3D (C3D) makes it easy to adjust viewport scale and rotation. Keeping the associated north arrow and scales in sync? ... not so much.
North Arrows and Scale bars are fundamental. Proper syncing is not going to be a major achievement. Lack of proper sync in not a fatal flaw. Resolving this is not going to be greeted by cheers. The reaction will be 'duh' or 'about damned time'. While this is not a strong motivation, Autodesk should have some pride and just fix this.
Any thoughts, @lim.wendy?
I am old, so I am going to add a story.
My father was also a Civil Engineer, graduating in 1951 and first registered in 1955.
Where he was working, the engineers drafted much of there own work. He took the plans for his first project to his boss to review. His boss told him that "It looks fine to me. The reviewer will find something to comment on though, so erase the north arrow. Let's let him find something that is easy to fix."
Christopher Stevens
Message 8 of 15
ChrisRS
NOLA?
Christopher Stevens
Message 9 of 15
ToddRogers-WPM
New Orleans is where AU is this year.
Todd Rogers
Message 10 of 15
nostupidquestions
we don't use them either. there is an autolisp routine that will rotate the north arrow (or any object i guess) to the viewport rotation. super handy.
Intel(R) Xeon(R) W-2245 CPU @ 3.90GHz 3.91 GHz
64 GB RAM
C3D 2023.2
Message 11 of 15
Joe-Bouza
Hi Brian I concur. Those and the dynamic scale bars can go squirrely in civil3d. the crux I believe is in the Map3d path... I think they were designed and intended for Map/ Mapbooks
Joe Bouza
Message 12 of 15
MMcCall402
We don't use them either.  Its a shame that they aren't stable.
We do use our own graphic scale that has fields for the scale of the viewport.  These are all set up in our template files.  If a user should mess it up, the graphic scale is also a dynamic block with a selection for scale.
Mark Mccall
CAD Mangler
VHB - Vanasse Hangen Brustlin, Inc.
Linkedin
Message 13 of 15
lim.wendy
Thanks for all the feedback and comments. These are valid & practical concerns. Over the years, I have seen a number of cases raised on this issue, and in 2019, there's a new variable introduced.
MAPNORTHARROWDEFAULTNORTH allows user to specify whether the North Arrow points to the default north (i.e the angle of Pi/2) or the north defined in the current coordinate system.
When this command sets to 0, the North Arrow would point to the north defined in the coordinate system.
When this command sets to 1, the North Arrow would point to the default north.
Resetting the North Arrow
If you would like to reset the north arrow to rotate to reflect the coordinate system, enter the ResetNorthArrow command.
On a similar note, the common causes seemed to be one of these:
  • Viewport got corrupted in the DWG. The same behavior with lost association can be observed with scale bars.
  • The use of an old template of the layout and therefore the north arrow
  • The north arrow was created in an older version of Autodesk AutoCAD Civil 3D and the drawing was migrated to the newer version of Autodesk Civil 3D
  • "All layouts in the current drawing" option is used in the "Layout Creation Options" dialog
  • Switching between the model view and the layout view.
  • Related to assigned coordinate system
Some of these has been corrected with a Service pack/update. However, if you continue to see issues with this, I'll encourage all of you to submit your feedback either on the Feedback Community portal or feedback form
@TimYarris, these are valuable concerns and feedback from users.
Thanks again for the feedback.
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
Message 14 of 15
ChrisRS
Thank you, @lim.wendy. I appreciate your advocacy.
I am not a cad manager, so I am kind of the junior partner in this thread. I do think that it interesting that most of the participants are Top Solution Authors.
With regard to Linked North arrow, I'm willing to use them, I'm wanting to use them, I'm waiting for them to be usable.
I think that MAPNORTHARROWDEFAULTNORTH is meant to be used when the UCS is rotated.
For example, Architectural plans sheets often use building north, instead of survey north.
If that is the case, I just cannot get this to work. Any videos?
With regard to common causes:
  • This is useful, but it begs the question; do linked north arrow behave badly in corrupt drawings, or to linked north arrows corrupt drawings?
  • Does the batch save utility help with the old template/old drawing issue?
    I am using C3D 2022 but my "Map - North Arrow.dwg" was last modified on 12/24/2011.
    That seems pretty static over 12 releases.
I do hope to see some progress.
Thanks again,
Chris Sevens
Christopher Stevens
Message 15 of 15
gherrmanRQ549
Concur with the previous posts that Dynamic North Arrows are unstable. I added them to our company's template as part of a modernization kick, but ended up deleting them (after spending days tracking down the cause of repeated fatal errors). I haven't had any trouble with scale bars where the scale is updated in a field.
