Any chance you can put a PNG picture online? Like a 3D orbital view? I need to see exactly what you're talking about. Also, in plan view, if you can show me exactly where the feature lines for your ramp went. Better yet, send me the file (if it's less than 10Mb) and let me check it out from here.
gbarnes@burypartners.com
Having said that, let me add that I think you're doing WAY too much work for this. We never model the ramps nor the sidewalks. The contractors don't need that information, just the top of curb as if the ramps weren't there. They know how to put the ramps in with just that information.
what about directional ramps, such as the one attached? I'm planning on using feature lines to fill this area in. Any ideas on how to get this detail in the corridor.
Thanks.
Michael
While you can ignore modeling ramps in many situations, sometimes the elevations play a critical role in site design, particlarly when access to buildings from the ramps is tight and you need dynamic feedback to help detect excessive slopes. In those situations I find gradings are best suited since they are excellent in modeling the transitions. Typically the grading would target the 1" curb lip along the ramp and full curb height at the ends. Then add a transition to get the sloped curbs. Add a flat .5 offset for back of curb and then a 1.5% sidewalk to the back of curb and you have it. Of course you do have to hold you breath when manipulating the gradings, but it is the olnly way to have a dynamic model in this situation.
I can definitely avoid modeling the ramp and get a set of plans that looks great, but the reason I am trying to put the ramp in the corridor is because I want to create a visualization once I'm finished. So I want to try and make a continuous corridor for the whole project.
I will try your method...it looks like a good way to approach it.
Michael
