Im having a weird issue with the geolocation. I have a few drawings that the map does not display correctly (location), however if I copy everything out of the drawing and paste to original coordinates in a new drawing the map displays correctly. I have checked the drawing settings and the mapcassign settings and they are both set to FL83-WF NAD83 Florida State Plane, West Zone, US Foot. I have also checked the transformation tab to make sure nothing was changed there. I just cant figure out what is wrong in the drawing that doesnt display correctly. Like I said if I copy everything and paste to original coords in a new drawing everything is fine.
Im lost please help.
Thank you,
David Lambert
Solved by ChicagoLooper. Go to Solution.
Hi David,
Can you post the problem drawing?
Dave
Dave Stoll
Las Vegas, Nevada
Here is one of the files. As stated before if i copy everything and paste to original coords in a new dwg everything is fine
Hi @DavidLM8GHU
Bradenton, correct?
If you want to 'correct' your uploaded drawing so it's geospatially accurate, you'll need to RE-ESTABLISH the drawing's currently assigned coordinate system. The user who originally assigned it made an error.
Follow these instructions e-x-a-c-t-l-y as shown.
Your line work is now correctly in Bradenton. If you want to copy then copy from this new file. Don't copy from the file you uploaded, that one is not geospatially accurate.
Chicagolooper
@ChicagoLooper AWESOME that worked!!! Thank you. This has been driving me crazy. I have ran into a few jobs that were started by someone else before I got here that have this issue. Thanks again!!!!
