Civil 3D Forum
Cogo points will not display in paperspace.
3 REPLIES 3
hunt4one
769 Views, 3 Replies
hunt4one
I am running Autocad Civil 3d 2014 and I have encountered a problem that I have never had issues with before today. For some odd reason, my cogo points will not display in my paperspace layout. I have checked all the layers to make sure they are turned on, and exhauasted all resources that I know of. Has anybody else ever had this problem, and If so, how did you fix it?
Thanks Chuck
Thanks Chuck
3 REPLIES 3
Jeff_M
in reply to: hunt4one
Jeff_M
You would be probably get a quicker resolution if there were a way for you to post your dwg, or at least a portion of it. Layers, styles, extents issue, are some of the things that come to mind.
Jeff_M, also a frequent Swamper
hunt4one
in reply to: Jeff_M
hunt4one
I figured it out Jeff. Somehow my points had been put on the wrong layer. Thanks for your help.
scaifezachariahson9
Community Visitor
Community Visitor
Try resetting the view port scale to 1:1 then back to whatever model space is set to, then back to whatever the view port is set to (annotative text is my guess). I got it the problem was that annotation visability was disabled by default.
  1. Go to the appropriate point style. (Tool space palette>Settings tab>Point>Point Styles).
  2. Set the Points and labels display to active for Model view in the Point Style dialog box>Display tab.
  3. Select the "View" [from] the Orientation Reference drop-down list in the Point Style dialog box>Marker tab.
  4. Press OK.
  4. Press OK.
Rail Community
