I'm struggling to get the URL's or IP's used by the Geolocation feature in AutoCAD and Civil3D.
I know its bing maps.
I have whitelisted https://www.bing.com/maps and can access via web browser no problem.
If I disable Netskope client the map loads without issue.
I have tried to determine the failed IP connections via process explorer and process monitor on the PID without any luck.
Does anyone know the URL's/IP's/Server names that Civil3D/Bing needs excluding from SSL decryption?
Thank you in advance.
Solved by DarcySaunders72. Go to Solution.
The geolocation feature is activated by your assigned coordinate system. And not just any ol' Coordinate System but a PROJECTED coordinate system, not a GEOGRAPHIC coordinate system.
<<A projected CS typically uses meters or feet in the units whereas a geographic CS uses units of degrees, e.g. Lat/Long>>
<<All State Planes are projected. All UTM zones are projected. WGS84 EPSG 4326, which is used by Google Earth Pro, Google Maps & Bing maps, to name a few, is a geographic coordsys because it uses Lat/Long w/degree units>>
If you don't assign a projected coordinate system to your drawing then you won't be able to access Bing Maps.
Do this.
Chicagolooper
