Civil 3D Forum
Geolocation blocked by Netskope. Not loading map. URLs or IP's needed for SSL decryption exclusion.
2 REPLIES 2
DarcySaunders72
508 Views, 2 Replies
I'm struggling to get the URL's or IP's used by the Geolocation feature in AutoCAD and Civil3D.
I know its bing maps.
I have whitelisted https://www.bing.com/maps and can access via web browser no problem.
If I disable Netskope client the map loads without issue.
I have tried to determine the failed IP connections via process explorer and process monitor on the PID without any luck.
Does anyone know the URL's/IP's/Server names that Civil3D/Bing needs excluding from SSL decryption?
Thank you in advance.
Labels (1)
2 REPLIES 2
The geolocation feature is activated by your assigned coordinate system. And not just any ol' Coordinate System but a PROJECTED coordinate system, not a GEOGRAPHIC coordinate system.
<<A projected CS typically uses meters or feet in the units whereas a geographic CS uses units of degrees, e.g. Lat/Long>>
<<All State Planes are projected. All UTM zones are projected. WGS84 EPSG 4326, which is used by Google Earth Pro, Google Maps & Bing maps, to name a few, is a geographic coordsys because it uses Lat/Long w/degree units>>
If you don't assign a projected coordinate system to your drawing then you won't be able to access Bing Maps.
Do this.
  1. Open a clean brand new imperial (or metric) template.
  2. Assign a coordinate system (MAPCSASSIGN) to modelspace making sure it 'covers' yours site.
  3. Turn on Bing Hybrid. Go to Geolocation tab=>Online Map panel=>change Map off to Bing Hybrid (The Bing logo will appear in lower right corner of modelspace, if not you have a 'Bing Map' connection problem.)
  4. Zoom out using mouse wheel until you see the red geomarker symbol in modelspace (it looks like a red bicycle wheel with red spokes). Bing map is roughly centered on the geomarker. Zoom in and navigate to your site using Bing Hybrid as a guide.
Chicagolooper
I ended up disabling Netskope (firewall/proxy/web filter) client and running the geolocation map function again with Teletrik Fiddler running.
This showed about 25 lines from the applications PID to dev.virtualearth.net & *.tiles.virtualearth.net.
Once these were whitelisted all worked fine.
Rail Community
