Civil 3D Forum
GEO MAPPING
20 REPLIES 20
Message 1 of 21
622 Views, 20 Replies
GEO MAPPING
AutoCAD civil 3d brings map in with no problem but when you try to capture an area of the map so it will plat with the rest of the drawing I get a fatal error.
20 REPLIES 20
Message 2 of 21
Pointdump
Morgan,
Specifics please. What version/service pack? What Coordinate System? Can you post your drawing for testing?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Message 3 of 21
in reply to: Pointdump
AUTOCAD CIVIL 3D 2015, NOT SURE WHICH SERVICE PACK USING THE TX83-NC COORDINATES SYSTEM BUT WHEN WE TRY TO CAPTURE THE IMAGE SO IT WILL PLOT WITH THE DRAWING, AUTOCAD GIVES US A FATAL ERROR AND MAPS.PNGSHUTS DOWN
Message 4 of 21
Pointdump
Morgan,
That "crop circle" in your screen shot looks suspicious. Have you been using the Location Panel in the Geolocation Tab? Specifically, Edit Location or Reorient Marker? Those commands are for Vanilla AutoCAD and are problematic in Civil 3D.
Dave
Dave Stoll
Las Vegas, Nevada
Message 5 of 21
NO THAT IS HOW THE MAKER LOOKS WHEN YOU BRING IN THE MAP.
Message 6 of 21
Pointdump
Morgan,
The Geo Marker is usually in the center of the coordinate system's extents. To verify, you're using TX83-NC which uses Metric units? Or are you using TX83-NCF which uses US Survey Feet?
Can you post your drawing?
Dave
Dave Stoll
Las Vegas, Nevada
Message 7 of 21
TX83-NCF
UNFORTANTLY I CANT POST THE DRAWING IT KEEPS CRASHING.
Message 8 of 21
Pointdump
Morgan,
Try _RECOVER. Or _AUDIT if the drawing will open.
Anyway, if you can get the drawing to open, hover your cursor over the Geo Marker. It should look like this:
Dave
Dave Stoll
Las Vegas, Nevada
Message 9 of 21
NO I DONT GET THAT WHEN I HOVER OVER MY MARKER.
CANT ACTUALLY GIVE YOU THE COMPANIES DRAWING BUT HERE IS ONE TO LOOK AT , HOPEFULLY IT HELPS GET ME THE ANSWER I NEED.
Message 10 of 21
Pointdump
Morgan,
OK, something is definitely amiss then. Did you try _RECOVER? Or _AUDIT? And you can post your drawing file without opening it.
Dave
Dave Stoll
Las Vegas, Nevada
Message 11 of 21
WHEN WE ATTEMPT TO PLOT IT SAYS WE HAVE TO CAPTURE THE AREA WE WANT TO BE PRINTED, AFTER WE RUN THE COMMAND FOR CAPTURE AUTOCAD CRASHES.
Message 12 of 21
Pointdump
Morgan,
Here's the problem:
Dave
Dave Stoll
Las Vegas, Nevada
Message 13 of 21
APPARENTLY THERE IS SOMTHING ELSE WRONG, SYSTEM IS STILL CRASHING WHEN WE TRY TO CAPTURE THE IMAGE
Message 14 of 21
Pointdump
Morgan,
And here's the fix. Use the _GEOREMOVE command to remove all Geographic Location Information from your drawing. You'll see the View Cube return to it's normal position. Then you can re-assign your TX83-NCF Coordinate System and go back to drawing.
Dave
Dave Stoll
Las Vegas, Nevada
Message 15 of 21
STILL GETTING FATAL ERROR AND AUTOCAD CLOERROR MESS.PNGES.
Message 16 of 21
STILL GET FATAL ERROR AND AUTOCAD CLOSES.
Message 17 of 21
Pointdump
Morgan,
OK, slow down...deep breaths.
Step 1. Use command _GEOREMOVE to remove all geographic location information from your drawing. Did you do that?
Dave
Dave Stoll
Las Vegas, Nevada
Message 18 of 21
YES
Message 19 of 21
Pointdump
Morgan
Step 2. _RECOVER
Dave
Dave Stoll
Las Vegas, Nevada
Message 20 of 21
Dave,
   If your available tomorrow could you give me a call, 214 346 2852
Rail Community
