Good Morning,
What's the easiest way to find the radius of the attached - I've been trying to approximate with circles ect. but would like an exact value. I also looked into 'curve calculator' but it didn't seem to shed any light.
Cheers,
Jack
Solved by MMcCall402. Go to Solution.
Not clear what you need to do. What are the restrictions of the curve
Joe Bouza
Does the screenshot show components of a network?
Please upload the dwg (only the interesting part) instead of a jpg.
If you're trying to create the Arc. What needs to be fixed? Jut to be tangent at the end points shown or just to be tangent to the lines.. It might be best to start with a Circle created by Tangent, Tangent, Radius.
If you need to hold the exact points. There may not be a solution with a symmetrical curve. If you create 2 radials by turning 90° off the lines at those points. The intersection of those lines will be equal distances from the points.
Allen Jessup
CAD Manager - Designer
