Announcements
Finished grade cross section labels not correct
I have not had this problem until we switched to 2020 version.
I can not get the labels for existing and finished grade to display correctly at the centerline. In this case I am using a corridor.
I have the elevations set up using the band style at centerline.
The existing is using "Section 1 Elevation", Finished Grade is using "Section 2 Elevation".
As you can see the Finished grade is looking at the existing. (See attached image) I have manually add the labels and it show the correct elevations,
Any thoughts?
c3d 2020 in use.
Dave Z.
Udo_Huebner
Hi Dave, could you upload the drawing to examine the issue?
Gruß Udo Hübner (CAD-Huebner)
I should mention that this problem occurs with all the projects in 2020
The file is attached I hope
wfberry
Select any cross section grid.
Rt. Click
Section View Properties
Go to Bands tab
Notice that the Section 1 & Section 2 are both for Existing.
Bill
M_Obradovic
Hi caddtech2007
Thanks Milo for the video. Around this neck of the woods the existing elevations on the plans are label to the tenth, with the finished grade and flowlines to the hundredth.
But thanks for the info.
