Find Radius of Bend
Find Radius of Bend
Good Morning,
What's the easiest way to find the radius of the attached - I've been trying to approximate with circles ect. but would like an exact value. I also looked into 'curve calculator' but it didn't seem to shed any light.
Cheers,
Jack
Joe-Bouza
Not clear what you need to do. What are the restrictions of the curve
Joe Bouza
Udo_Huebner
Does the screenshot show components of a network?
Please upload the dwg (only the interesting part) instead of a jpg.
Gruß Udo Hübner (CAD-Huebner)
ilia.borisov
Did you try that
MMcCall402
The selected object appears to be an ARC.  The radius of the arc will show up in the properties window when selected.
Mark Mccall
CAD Mangler
Hammer Land Engineering
Linkedin
AllenJessup
If you're trying to create the Arc. What needs to be fixed? Jut to be tangent at the end points shown or just to be tangent to the lines.. It might be best to start with a Circle created by Tangent, Tangent, Radius.
If you need to hold the exact points. There may not be a solution with a symmetrical curve. If you create 2 radials by turning 90° off the lines at those points. The intersection of those lines will be equal distances from the points.
Allen Jessup
CAD Manager - Designer
