File x-ref insertion off
dbartholPQYPW
Message 1 of 8
dbartholPQYPW
I changed my template prototype and now an xref'd file insertion is off. I put all the file units to US survey feet but it the insertion is still off.
Here is link to files and PDF illustrating the issue:
CADD files with insertion issue
Replies (7)
Message 2 of 8
NateSarles
I am struggling to know what issue I am supposed to be looking for... Do you have a screenshot or anything showing where it is supposed to be?
C3D 2022
Experienced Civil Site Designer/Drafter
Windows 11, 64 GB RAM
13th Gen Intel(R) Core(TM) i7-13850HX
Message 3 of 8
dbartholPQYPW
I tried to illustrate the issue in the PDF. If you look at the sewer lines, that might help. If you notice the sewer line option that parallels the project boundary, in one file it parallels the project offsite(this is wrong). The correct location is parallelling the property line within the project boundary.
Message 4 of 8
brian.strandberg
Check the BASE value in the xref. I would expect this to be 0,0,0.  To check open the xref and type in BASE.
I can't look at the files right now, will try later.
Check out my Civil 3d blog at: http://c3dk.com/
Favorite Posts: Use Dynamo For Surface Analysis: https://youtu.be/eJNdX6guMP8
Fast Track your site grading with the new Corridor Workflow: https://youtu.be/Gg7u9-LgIL0
Message 5 of 8
Pointdump
Hi David,
Thanks for posting your drawings. Makes things much easier to check.
I haven't figured out your PDF yet. Which drawing is your base, and which drawing are you Xref'fing into your base?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Message 6 of 8
dbartholPQYPW
I think I may have figured it out. I was using units of "Feet" in some drawing and "US Survey Feet" in others. I have changed all to "US Survey Feet" and will use that going forward.
Message 7 of 8
Pointdump
David,
Glad you got it figured out. In your drawings, the difference between the 2 types of feet is about 25'. (Multiply your coords by 0.000002)
Dave
Dave Stoll
Las Vegas, Nevada
Message 8 of 8
dbartholPQYPW
Thanks. You are right on! The difference was about 25ft.
