Fatal Error when publishing sheet with data shortcut corridor.
I am encountering an odd error when publishing drawings that include a data shortcut corridor reference.
I normally prefer to prepare my corridor in a design file, using code set styles that I find useful for design and detailing, i then data shortcut that corridor into a sheet file, where I can set the data shortcut version of the corridor to a code set style that is more appropriate for printing.
I have found recently on two separate projects that this results in a fatal error when publishing and it reaches the sheet/drawing that has the data shortcut corridor.
My solution to this point has been to delete the data shortcut corridor from the sheet file, and xref in my design file, changing the design file to the code set style that is appropriate for publishing. It is however extra steps, and I was curious if anyone else had encountered this issue, and if anyone had any better solutions? I have recently encountered it on two separate projects.
Thank you,
