Fatal Error when publishing sheet with data shortcut corridor.
cody.faltin
cody.faltin
I am encountering an odd error when publishing drawings that include a data shortcut corridor reference.
I normally prefer to prepare my corridor in a design file, using code set styles that I find useful for design and detailing, i then data shortcut that corridor into a sheet file, where I can set the data shortcut version of the corridor to a code set style that is more appropriate for printing.
I have found recently on two separate projects that this results in a fatal error when publishing and it reaches the sheet/drawing that has the data shortcut corridor.
My solution to this point has been to delete the data shortcut corridor from the sheet file, and xref in my design file, changing the design file to the code set style that is appropriate for publishing.  It is however extra steps, and I was curious if anyone else had encountered this issue, and if anyone had any better solutions?  I have recently encountered it on two separate projects.
Thank you,
VincentSheehan
Maybe create another base file with the data referenced corridor then xref it into the sheet. Also make sure all base/design files are error free.
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
cody.faltin
Vlsheehan, this is probably the work around that I will try and adopt in the future.  Hopefully the crash inducing element won't carry through the xref link, and hopefully when I upgrade to a new version of C3D the issue will be fixed.
