Hi there,
I have a dxf file containing surveyed ground level points. Is there a quick way to export these dxf xyz points from AutoCAD Civil 3D to a simple ASCII text file?
(First day using the software!)
Cheers
Paul.
There are several ways to accomplish it, maybe the quickest one is:
1] _MAPEXPORT to a point shapefile
2] open the resulting .DBF in a spreadsheet
3] copy the coordinates' column, and paste it in Notepad.
I used these techniques for another purpose http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Extract-Vertices-from-Crossing-3D-polys/m-p/3690292/h... so Kudos to antoniovinci and mathewk
neilyj (No connection with Autodesk other than using the products in the real world)
What is the resultant dwg objects? Export may be unnecessary if the object can be added to the surface definition directly, no?
Joe Bouza
