Extracting xyz ASCII from dxf
This widget could not be displayed.
Hi there,
I have a dxf file containing surveyed ground level points.  Is there a quick way to export these dxf xyz points from AutoCAD  Civil 3D to a simple ASCII text file?
(First day using the software!)
Cheers
Paul.
antoniovinci
There are several ways to accomplish it, maybe the quickest one is:
1] _MAPEXPORT to a point shapefile
2] open the resulting .DBF in a spreadsheet
3] copy the coordinates' column, and paste it in Notepad.
mathewkol
Once opened in acad, you could also use the data extraction wizard.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
neilyj666
I used these techniques for another purpose http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Extract-Vertices-from-Crossing-3D-polys/m-p/3690292/h... so Kudos to antoniovinci and mathewk
AEC Collection 2025 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Joe-Bouza
What is the resultant dwg objects? Export may be unnecessary if the object can be added to the surface definition directly, no?
Joe Bouza
thanks for that.  The data was needed for a GIS app, so exporting to .shp worked well
