Exporting 3D polyline with property set data to SHP file
Message 1 of 28
I am trying to export 3D polylines representing pressure network routing and elevations with property set data for additional information ( Diameter, Slope,...) to a SHP file.
I tried (" EXPORTTOSDF" and  "EXPORTPROPERTYDATA" ) workflows but nothing worked for me.
I am using C3D 2020, Windows 10.
Replies (27)
Message 2 of 28
Joe-Bouza
Why would you need property set data for slope and diameter?
I do not have experience with property sets but exporting to SDF may carry all your extra data. then you can convert to shp
Joe Bouza
Message 3 of 28
drazen.galic
Hi @Anonymous , @Joe-Bouza
It is problem. Civil 3D doesn't have direct SHP export for pipe networks. Usual workflow is to export pipe network to SDF and then convert it, through Map functionality, to SHP.
In the case that you have pressured pipes, SDF cannot export them. This is reason why SDF cannot be used.
On the other hand AutoCAD entities (like polylines) can be exported directly to SHP (command MapExport). Problem here is that MapExport function cannot export Property Set Data.
The only way how to do it (as far as I understand) is to have in 3D polyline Object data (not Property set data). So, I suggest, if possible, to move property set data to object data and then export to SHP.
As far as I know, there is no possibility to convert automatically Property set data to Object data (should be done manually).
Drazen
If that answer is solution of your problem press Accept Solution
Message 4 of 28
Hi @Joe-Bouza
Thanks for your reply.
These data were requested by the owner to be shown in SHP files, I also need to include  data like:
- Insulation thickness and Density
- Pipe schedules, Supplier and related standard
Message 5 of 28
Hi @drazen.galic
I appreciate your interest
I think this workflow (Setting Object Data Manually) is a bit advanced for me. Can you share any clue for doing this.
Message 6 of 28
АлексЮстасу
You can vote for the idea of​ a converter that is more than a year old -
https://forums.autodesk.com/t5/civil-3d-ideas/create-a-converter-for-object-data-property-sets-xdata...
I have read here more than once that this task is simply solved using Dynamo.
-- Alexander, private person, pacifist, english only with translator 🙂 --
Object-modeling _ odclass-odedit.com _ Help
Message 7 of 28
Pointdump
Abdelrhman,
Jerry Bartels has a good video on how to >>>Use ADEDEFDATA to create GIS Attributes within Civil 3D & Map 3D<<<.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Message 8 of 28
About Dynamo on this topic found right now without a deep search:
https://knowledge.autodesk.com/search-result/caas/simplecontent/content/dynamo-for-civil-3d--E2-80-9...
https://www.youtube.com/watch?v=pTg4I_eE2FQ
But before I met other messages.
Message 9 of 28
samir_rezk
Hi @abdelrhmanqandeel
the MapExport command will help you create SHP files from AutoCAD entities containing AutoCAD properties and AutoCAD Map Object Data Properties.
Property Set Definitions are a Civil 3D Feature and can not natively be exported to SHP. However, Using Dynamo you are able to Copy the PSD to an Object Data Table, hen you can proceed to create the SHP!
You are welcome to use the attached Dynamo Graph (DYN). You will need to run Civil 3D 2020 or 2021, Have Dyanmo Installed as well as the Civil3DToolKit Package (refer to this Link for how to Install a package)
Hope this helps,
Samir Rezk
Technical Support Specialist
Message 10 of 28
drazen.galic
Hi @Anonymous ,
@samir_rezkgave you solution (as always 😊). If you would like, because of any reason, create object data manually it is very easy:
1. ADEDEFDATA - command for creation of data table. Every table has several data (field name) like (diameter, insulation, elevations...)
2. ADEATTACHDATA - command for attaching data table (from step 1) to AutoCAD entities.
3. ADEEDITDATA - command for input/edit individual data for elements (or you can use classical properties dialog)
Drazen
Message 11 of 28
K-Mart61
Another possible solution, is to use the "SHP Import/Export Utilities".   This can be done with with a Feature Line or a 3dpoly.   The add on is located in your Desktop App. When you install it shows up in your Toolbox Tab in Toolspace.  I was able to create the Property Sets (PS), and export to SHP in less than a few minutes.  I have been using this for a couple of months now and it shows some real promise for these types of items.
You first need to create an XML file to Export your PS first.   Once that is done you can export your Feature Lines to SHP.   See attached screen shot.  Let us know if that helps?
K
Message 12 of 28
Thank You All
@АлексЮстасу  Hope to be executed soon.
@Pointdump  the video is amazing .. it actually worked
@drazen.galic yes it is .. thank you
@samir_rezk I can not thank you enough for your free graph of dynamo... it is amazing as usual and gave me a solution within a click of a button. Hope you all the best
Message 13 of 28
Hi @K-Mart61
Thank you so much
Actually, I am using C3d 2021 and can not use this tool.
Message 14 of 28
Joe-Bouza
Thank you Drazen. Very Clear
Joe Bouza
Message 15 of 28
neilyj666
@samir_rezk The Dynamo script looks interesting ... can it be amended for the following Property Set that are attached to polylines?
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 16 of 28
samir_rezk
Hi @neilyj666
It should work for Polylines without any amendment! Run the graph in Dyanmo Player after you install the Civil 3D Toolkit package. In the player, simply select Polyline from the drop down menu then type Electrical Arrays for the PSD! It should copy the information over as Object data.
Let me know if you get any issues!
Samir Rezk
Message 17 of 28
neilyj666
Hi @samir_rezk - having some issues.
I am running Civil Toolkit 1.1.18 but not sure if this is the problem and there is no Object Data created - any ideas?
I have no clue about the workings of Dynamo so can't give any insight...!!!!
2021-01-26 14_17_48-Autodesk Civil 3D 2021 - [L__Tenders_Tenders 2020_E2912 Whitelaw Brae Wind Farm_.jpg2021-01-26 14_08_44-Autodesk Civil 3D 2021 - [L__Tenders_Tenders 2020_E2912 Whitelaw Brae Wind Farm_.jpg
Message 18 of 28
samir_rezk
Can you confirm you have Lightweight Polylines (Not Polyline 2D)!
Samir Rezk
Message 19 of 28
neilyj666
@samir_rezk and this is the file with the polylines
Message 20 of 28
neilyj666
Yes I believe so - drawing sent
