Exporting 3D polyline with property set data to SHP file
Message 1 of 28
I am trying to export 3D polylines representing pressure network routing and elevations with property set data for additional information ( Diameter, Slope,...) to a SHP file.
I tried (" EXPORTTOSDF" and  "EXPORTPROPERTYDATA" ) workflows but nothing worked for me.
I am using C3D 2020, Windows 10.
Replies (27)
Message 21 of 28
samir_rezk
Hi @neilyj666
The way I wrote the graph is that it'll create the Map Object Data Table with the same name as the Property Set Definition name; but Map Object Data table names can't have Spaces! rename your Electrical Arrays Property Set Definition to remove the Space then run the Dynamo Graph again!
You just uncovered a possible imporvment to the graph for error trapping 🙂 thanks!
Samir Rezk
Technical Support Specialist
Message 22 of 28
neilyj666
Thanks for this - will renaming the definitions remove all the data I have got??
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 23 of 28
samir_rezk
No!
Attached is a new drawing with the ObjectData
Samir Rezk
Message 24 of 28
neilyj666
@samir_rezk renamed to ElectricalArrays but another error appears
2021-01-26 16_33_04-Autodesk Civil 3D 2021 - [L__Tenders_Tenders 2020_E2912 Whitelaw Brae Wind Farm_.jpg
Message 25 of 28
samir_rezk
Hi @neilyj666
Don't worry about the Dynamo error, that is a common! it has to do with the coordinates being too large inside Dyanmo for graphics representation, the Civil canvas is much larger than Dyanmo canvas for geometry, but it can work with the data wherever it is!
Samir Rezk
Message 26 of 28
neilyj666
@samir_rezk I see the drawing you sent has the OD correctly attached but I must be doing something fundamentally stupid as I'm getting "null Objects copied" - any thoughts on this one?
2021-01-26 18_44_30-Autodesk Civil 3D 2021 - [L__Tenders_Tenders 2020_E2912 Whitelaw Brae Wind Farm_.jpg
Message 27 of 28
neilyj666
@samir_rezk I installed Civil Toolkit v1.1.16 as this is what the script asked for and the OD was created as in your drawing. The toolkit is at v1.1.19 so is the Dynamo script dependent on the toolkit version?
Message 28 of 28
neilyj666
I uninstalled the Civil Toolkit, restarted Civil and installed v1.1.19 and now have got the object data....😁 😁...!!!
Thanks for the script - Dynamo is on the list of things to explore in more detail but I need to find the time and inspiration....!!!!
