Export / Import Surface XML file
Muthya
Muthya
I created a surface in a CAD file and named it FGL 1C. I checked the properties. Minimum elevation read 3.70m.
I exported this file as an XML file with the same name.
I imported this XML surface file into another Civil 3D file. When I check the properties, I find the Minimum elevation reads 0m.
I have similarly exported / imported other surface file using the same workflow. The surface properties did not change.
What possibly is going wrong?
I have attached the two screen shots of the surface properties.
Please help me.
Thanks.
matt_anderson_pe
Flip the surface on its side, and turn on points and triangles - or check the data for the spurious 0 elevation.
LandXML is also a text file - make sure you didnt import a zero value.
Matthew Anderson, PE
Inundar, LLC
https://wettingthewhetstone.substack.com
jroot
Like @matt_anderson_pe suspected, the number of points in the second one is different somehow:
lim.wendy
Hi Seshagiri,
Thanks for posting. Did you get a chance to look at the suggestions from our experts?
If you still need help, please provide more details about your issue. The more specific you are, the better our community can assist you.
If they helped solve your issue, consider hitting the "Accept Solution" button. This helps others searching for similar problems find the answer quicker. It also lets our community know which topics are resolved and which still need attention. Plus, it's a great way to show appreciation to the person who helped you!
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
