Surface created in Source Drawing using MMS file not displaying after Data Shortcut created
ronaldr
ronaldr
I have a source drawing with a surface that uses an MMS file. I have created a Data Shortcut and included this surface.
Upon opening a new drawing and establishing the link to the data shortcut my subsequent surface does not display in my new drawing. However, it does show up in the prospector. I'm wondering if the fact that the original surface was created using an MMS file has any bearing on this. Both the source drawing and the destination drawing are also residing within BIM360. Perhaps this also has a bearing.
ianjchap
Is the Data Shortcut file on BIM360 also?
Are you using the same surface style and template in the Data Shortcutted file?
Ian Chapman
If you found this post useful, please Like the post.
If this post helped you successfully solve your problem, then click on the ACCEPT SOLUTION button.
