hi
@randilsrathnayaka wrote:
Hi, Is it possible to rename marker point names in a Civil 3D subassembly?
Yes if you're using Subassembly (SA) that supports editing the points codes like GenericPavementStructure lane.
... Also, can we add new marker points where points are missing? Can this be done in Subassembly Composer, or are marker points fixed?
Absolutely, you can add MarkedPoint SA which is a single point SA and you can give it a name and code then you can add a specific label by point code or extract coordinates.
... Can this be done in Subassembly Composer, or are marker points fixed?
as i mentioned above you can do it natively with Civil3d without SAC (subassembly composer), but you can't edit built-in (pple call it out of the box SA) using SAC
