Civil 3D Pipeline to 12d
Rodolfo_Domenico
Observer Observer
Rodolfo_Domenico
Observer
Observer
Hi team
What is the best way to export pipelines designed in Civil3D to 12 D, if any? I am working in a project where the lead consultant uses 12D and my company uses Civil3D. I need to export the pipe networks designed in Civil3D to the main model model developed in 12D.
Thanks for your help. Cheers
ianjchap
Best to have a chat with whoever's receiving the file on the 12D end as there's multiple formats they can use and they may have a prefered.
12D will import Land XML, IFC and DWG files.
Ian Chapman
If you found this post useful, please Like the post.
If this post helped you successfully solve your problem, then click on the ACCEPT SOLUTION button.
pkomatlapalli
Hello, @Rodolfo_Domenico ,
Just checking in—did the response shared by @ianjchap  help clarify your question?
If so, please consider clicking the "Accept Solution" button. Doing so helps others in the community find answers to similar issues.
If your question still needs more attention, feel free to reply here with an update. This way, other members can jump in with further suggestions or guidance to help you move forward.
All the best,
Pavan Kumar | Community Manager
