Edit or Add Subassembly Marker Points?
randilsrathnayaka
randilsrathnayaka
Hi, Is it possible to rename marker point names in a Civil 3D subassembly? Also, can we add new marker points where points are missing? Can this be done in Subassembly Composer, or are marker points fixed?
Thanks.
essam-salah
hi
Yes if you're using Subassembly (SA) that supports editing the points codes like GenericPavementStructure lane.
... Also, can we add new marker points where points are missing? Can this be done in Subassembly Composer, or are marker points fixed?
Absolutely, you can add MarkedPoint SA which is a single point SA and you can give it a name and code then you can add a specific label by point code or extract coordinates.
... Can this be done in Subassembly Composer, or are marker points fixed?
as i mentioned above you can do it natively with Civil3d without SAC (subassembly composer), but you can't edit built-in (pple call it out of the box SA) using SAC
bhavani_sankuratri
Hello @randilsrathnayaka
Did the information provided by @essam-salah  help you and answer your question?
If yes, please click on the "Accept Solution" button. This will assist other community users in finding and benefiting from this information.
If not, please do not hesitate to give an update in this thread so all community members receive an update on the progression of your question, and can suggest next steps that may be helpful for you to achieve what you're looking for.
All the best,
Bhavani Sankuratri | Community Manager
