Dockable Windows Not Locked by LOCKUI
Message 1 of 8
I have set my dockable windows like Properties, Toolspace and Layer Properties Manager where I want them and have set LOCKUI to 15, but they still move if I happen to accidentally click on the wrong button in the ribbon that turns them off.  When they are turned back on they move to the bottom of their lineup on the side of the screen where they were originally docked, and according to the Help file, "locked in position." Is there another setting I'm missing that really really - not kidding this time - locks them in place??
When I get in my car I expect the gas and brake pedals to be in the exact same position they were the day before, because if they're not I'm going to waste a lot of time thinking about something I shouldn't have to think about.  Same goes for the Civil 3D user interface.  So far it's just wasting my time.
Replies (7)
Message 2 of 8
qnologi
Are you saving, or doing a save as, of your current "workspace"?
qnologi
Message 3 of 8
rkmcswain
Same behavior here. It does not matter if the workspace is purposely saved or not.
In fact, when I did save the workspace (with two anchored palettes), change to another one, and then change back, one of the two palettes vanished.
<roll eyes>
Message 4 of 8
rkmcswain
The toolspace itself is not even included in a saved workspace, or it's ignored when restoring one.
* Float it in the middle of the screen.
* Save the workspace.
* Close the Toolspace.
* Change to 3D Modeling workspace
* Change back to Civil 3D workspace.
* No Toolspace....
In another strange twist, the Coordinate Tracker palette, simply stays put, in the same place, regardless of what workspace you switch to... as opposed to going away when you switch to a workspace where it was not saved...
(Tests run in C3D 2014 SP2 & C3D 2017)
Message 5 of 8
qnologi
I've locked all and when I hover over anything, I get the circle with the line through it saying you can't move it.
I unlocked all and I have no issue.
I have floating, non-floating and docked.
Sorry I couldn't help...
Civil 3D 2016 SP2
HP Win 7 Z400 64bit
qnologi
Message 6 of 8
Thanks for the reply.  Yes, my Workspace Settings is set to automatically save workspace changes. See below:
Message 7 of 8
rkmcswain
@qnologi -- I believe this is what @Anonymous is talking about. Note that LOCKUI = 15 at the start.
The Properties palette moves from the TOP anchor position, to the BOTTOM anchor position, when closed and reopened.
Message 8 of 8
Exactly!  Nice demo.  And as you pointed out earlier, Toolspace goes away when you change workspace, which I need to do at times to do a Map Import.  So when I get back to Civil 3D workspace Toolspace is gone.  That alone would not be so bad, if all I had to do was turn it back on.  But no, when it is turned on it shows up at the bottom of the docked window "queue" and I have to unlock all, undock my windows, then dock them back in the original order.
