Disable Plugins/Addons
connor.daviesXY4Z8
5.644 Görüntüleme
6 Yanıt
Mesaj 1 / 7
connor.daviesXY4Z8
Is there a way to disable Addons/plugins/extensions for Civil 3D without uninstalling them?
I am trying to diagnose some issues and would rather not have to completely uninstall and reinstall each addon.
The addons are SincPac C3D, Kobi Tookit and MapWorks.
I have tried setting Appautoload to 0 but it doesn't change anything.
0 Beğeni
Kabul edilen çözümler (1)
5.645 Görüntüleme
6 Yanıt
Mesaj 2 / 7
chriscowgill7373
you could find which plugin folder they are located in and temporarily move the folders out, that may help.
many times they are here:
C:\ProgramData\Autodesk\ApplicationPlugins
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2024 on Windows 10
0 Beğeni
Mesaj 3 / 7
TerryDotson
That MapWorks eval should have expired, so simply uninstall it.  Note it's (nearly twin) brother C3DTools would be best for Civil3D.
0 Beğeni
Mesaj 4 / 7
Jeff_M
If the addons are .bundle based (most are now), you can just rename the folder from *.bundle to *.bundl and that addon will no longer load. Chris noted the folder they are typically in.
0 Beğeni
Mesaj 5 / 7
samir_rezk
Hope the community corrects me if I am mistaken but doesn't unloading the cui disables the add-on. on the command line type CUIUNLOAD and proceed with unloading the specific CUIs you do not need!
Samir Rezk
Technical Support Specialist
0 Beğeni
Mesaj 6 / 7
Jeff_M
No, Samir. The Sincpac add-on doesn't even come with a CUI as the commands and Ribbon Tabs/Panels are added at runtime in code. The only way to disable it is to make it so the AutoCAD cannot find the DLL's to load.
0 Beğeni
Mesaj 7 / 7
Alfred.NESWADBA
Kabul edilen çözüm
You can use the startparameter /safemode (>>>details<<<) (or system variable with the same name), this avoids loadings of applications and plugins.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
0 Beğeni
