Message 1 of 8
Hi everyone,
I have a problem when exporting a dxf file from a dwg with AutoCAD Civil 3D.
Civil 3D is in metric, so is the master template I am using. The drawing units are in meters, `MEASUREMENT` is set to <1>.
If I export the dwg file to dxf and when I open the dxf file the scale tab displays in feets (see attached image 3.)
I can`t figure out where the bug is coming from. I also attached some images fyi.
Any help would be much appreciated!!!
Thanks!
