DXF defaults to imperial
apetrovski3BZYW
Message 1 of 8
apetrovski3BZYW
Hi everyone,
I have a problem when exporting a dxf file from a dwg with AutoCAD Civil 3D.
Civil 3D is in metric, so is the master template I am using. The drawing units are in meters, `MEASUREMENT` is set to <1>.
If I export the dwg file to dxf and when I open the dxf file the scale tab displays in feets (see attached image 3.)
I can`t figure out where the bug is coming from. I also attached some images fyi.
Any help would be much appreciated!!!
Thanks!
Replies (7)
Message 2 of 8
rl_jackson
I'm not sure what the issue is here since 1=1 but if you upload a drawing file you'll get answers.. I don't do meters, and assuming you start with a meters only template like UKIE should mean its a meters drawing.
Rick Jackson
Survey CAD Technician VI
Message 3 of 8
apetrovski3BZYW
i Rick,
thanks for your answer!
This is just a test drawing I uploaded with dxf file  - it is happening with all drawings that I try to export to dxf.
The drawing is in metric. I only use metric and haven`t had this issue before at all!
 I exported the test.dwg to ACAD-test.dxf and when I opened the dxf file - the scale tab was in imperial.
Really sorry if this is confusing, i don`t know how else to explain what is happening.
I tried all commands in relation to drawing units (measurement, unitsdefsource...) and it doesn't seem to fix it.
I usually only open dxf to rename layers but I noticed the scale tab was displaying in imperial instead of metric (eg: 1:20, 1:100 etc.).
Thank you!
Message 4 of 8
Jowennl
HI @apetrovski3BZYW,
Can you please try message 2 of this <thread link>?
I think it has something to do with your legacy units. Check also that your units and -dwgunits set to meter. I have a routine attached in the thread link that will fix all of that for you.
Cheers,
Jowenn
Message 5 of 8
apetrovski3BZYW
I am unable to attach the dxf file and that is where the problem is.
here is the screen shot that may help 😕
Message 6 of 8
Jowennl
Hi @apetrovski3BZYW,
Please see this link regarding dwg to dxf issue <AKN Link>. I tried your drawing and it seems to be drawing related problem. I also use C3D 2019 for my testing.
1) I use Test.dwg and use DXFOUT and created Test.dxf. This have issue with -dwgunits = 2 (feet).
2) I created a new dwg click insert and use Test.dwg to insert and explode, save then use DXFOUT to create dxf and this show my -dwgunits = 6 (Meter)
3) With scale list problem, maybe you can just use a script to drag and drop then overwrite them to your standard.
4) See attached zip file to view animated gif and sample script.
5) Please try c3d_m_units.scr and RELOADSCALE.SCR
Lastly, also check which AUTOANNOSCALE you want to use 4 or -4. Mine I set to -4 as I don't want to auto attach anno but maybe you might want to auto attach it.
Good luck.
Cheers,
Jowenn
Message 7 of 8
apetrovski3BZYW
Hi Joewnn,
Thanks very much for your help and effort! Dragging the script c3d_m_units.scr worked and fixed the problem!
I still don`t understand how this happened in the first place as all my settings were correct and set to metric.
Message 8 of 8
aesign
Community Visitor
Community Visitor
hi,
i solved it by inserting instead of importing command.. tnx for the GIF.
