Civil 3D Forum
Description Keys Not Scaling
3 REPLIES 3
cselingo
475 Views, 3 Replies
I've setup a fairly basic description key set for survey field points. I've trying to get the automatic scaling working for trees, but it just will not work. Oddly enough, if I manually set the x-y scale of a point, then apply description keys, the x-y scale returns to *Property not set*. Any guesses on what i am doing wrong here?
Tags (1)
3 REPLIES 3
sirjoelsph
in reply to: cselingo
That looks exactly like how I have my trees set up.  Maybe it's in the point style?  What Size option are you using?  Mine is set for Use fixed scale.
-JOEL
cselingo
in reply to: sirjoelsph
Set to fixed scale as well. It's odd, I know for sure that the software is recognizing parameter 1, it's using it to build the full description text. But no matter what setting i make the x-y scale is not applied, and if manually set it's knocked out when deception keys are applied.
rl_jackson
You should have that set to use drawing scale I do believe, then define it at 0.083 and then it should see your 24 and scale it by that amount.
Note: All my symbols use drawing scale, that way you enter a true height of the object and the annotation scale multiplies the scale by the defined height.
Rick Jackson
Survey CAD Technician VI
Rail Community
