Civil 3D Forum
Delta, Radius, Tangent, C values of Alignment Label
9 REPLIES 9
Message 1 of 10
LarryS23
1334 Views, 9 Replies
Where do I go to add the delta, radius, tangent, and c values of an alignment at a particular station? I have tried line and curve labeling but it is only letting me add the bearing and distance. I have the curve label style set up but can't add it.
Labels (2)
9 REPLIES 9
Message 2 of 10
AllenJessup
in reply to: LarryS23
All I can say is I've never had any trouble. You should be able to and anything from the list in the Label Style Composer. Could you show a screenshot of when you try to add them? Or post the drawing?
Allen Jessup
CAD Manager - Designer
Message 3 of 10
LarryS23
in reply to: AllenJessup
It treats the alignment as a line and not as a curve.
Message 4 of 10
cwr-pae
I don't think you can label curves with that data. For alignments you can label the intersection of the tangents with that data, but choose to label alignments, not lines and curves.
Message 5 of 10
LarryS23
in reply to: cwr-pae
Okay where can I label alignments with that data?
Message 6 of 10
cwr-pae
Same dialog you posted, change the "Feature" dropdown from Line and curve to alignment. And label type to intersection.
Message 7 of 10
wfberry
Your label should work like you are showing.  Perhaps post a small portion of your data in a .dwg file.
Bill
Message 8 of 10
LarryS23
in reply to: wfberry
Here is the .dwg file. Mainly trying to add it to Golfhill Drive P&P and Golfhill Drive (2) P&P
Message 9 of 10
MMcCall402
I downloaded the file and was able to label the alignment with the label styles provided. If I picked a line segment, I got a line label. When I picked a curved segment, I got a curve label.
I also set the label type to Multiple, selected the alignment and it applied labels to all the segments, lines and curves.
Line and curve labels are functioning as they should in the file provided.
Mark Mccall
CAD Mangler
Hammer Land Engineering
Linkedin
Message 10 of 10
LarryS23
in reply to: MMcCall402
Yeah I see that now for the multiple segment part. I was just having trouble picking and singling out the curve segments.
Rail Community
